Either the spool in the valve is bypassing to the other port or a cylinder is bypassing around the piston quad-rings. Hard to say which one, though I would lean more towards the cylinder seals. The valve spool is a lapped to the vavle body and if it is leaking it must be replaced. If the loader is running off of the tractor remote valves and have quick-couplings, just unplug them and watch the bucket. If not, you could plumb a ball valve on each line and close them, if the bucket "relaxed" then it is the seals in the cylinder. Rebuilding the packing gland and piston in a cylinder is fairly easy. I take no responsibility if you use brass ball valves (cheap) and they rupture. But they should not if you do not deadhead the circuit (end of stroke). Hope this helps.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
