8 degrees isn't far off for doing the adjustment. Unless the magneto is rotated all the way against the engine block, you should be able to just set the timing. If not, the governor gear will need to be remeshed as Gene said. It isn't likely it "jumped a tooth". If it is off, the last person that worked on it assembled it wrong.
On the carb, somebody probably just replaced the original with what he had on hand.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
