#1. Throw the ether away... bad juju in glow plug engines...
#2. Crack all of the fuel line fittings at the injectors.
#3 crank until you have fuel there and no air coming out.
#4 tighten lines but not all of the way, let them seep a bit to continue bleeding air if it may be present
#5 Lean on the glow plugs for 60 seconds before turning her over - helps to know that all 6 glow plugs are in fact working.
Once it fires (assuming everything is put back together correctly) you can go back and bleed all of the lines while it is running to make sure all of the air is out.
Sorry Allen and Hugh but pull starting a tractor that has just been repaired can lead to bad situations. Either in broken parts and or run aways and in turn destroyed equipment and broken bodies...
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
