Comon' now Pard, you're not thinking this through.
How much gratification did that new front pump replacement give you as far as the 3-point operation goes? By your own admission, none. Zero, Nada.
Therefore……………………………
Your local IH mechanic probably means well, but he is just flat out mistaken on how that system operates.
Take the seat off the tractor. Remove the square plate above the three-point galley.
Then, without a load on your weak hitch, operate the hitch up and down a couple of times. It should move smoothly thru the up and down cycle, albeit slowly perhaps?
"IF" you see no "boiling" oil in that galley during hitch operation indicating a possible massive piston seal leak, o-ring leak or cracked cylinder, replace the REAR (piggyback) pump.
Yes, the one that is called the “hitch” pump.
They wear out and their first symptom is weak load lifting capacity. Second symptom is the hitch won't even move.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
