Posted by Owen Aaland on August 19, 2008 at 21:07:38 from (65.161.86.52):
In Reply to: 1066 power steering posted by cobra1379 on August 18, 2008 at 11:11:58:
Much more likely to be the seal between the clutch housing and rear frame. The suction tube will be completely below the oil level when the transmission is at the full mark. The o ring (quad ring) seal is above the oil level which allows air to enter. A small leak will allow the oil to drain back through the filter when the engine is off creating an air bubble which the front pump has a hard time clearing. A pump with some wear on it has an even harder time. It will not do any harm to run the system with an extra five gallons in it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
