Big Chuck said: (quoted from post at 19:51:26 08/19/08) I am trying to convert my M to 12 volts. The 12 to 6 volt reducer I bought for the coil wire didn"t reduce the voltage at all and ruined the coil. Can I just remove the reducer and use a 12 volt coil instead? If I do will I need to modify any part of the electriacl system? Thanks
If you just go to auto store and ask for a "ballast resistor", you can and will get anything from about 0.3 ohms up to about 2 ohms. Almost a 7 to one ratio. The 0.3 will not do much voltage reduction at typical 3 amp coil current. 0.3 ohm X 3A=0.9 volts. Far from a 6v reduction!
2 ohms X 3amps=6volts
You just never know what the parts guy will hand you.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
