Couple of things, most serial plates on those tractors have lost all information except stamped in serial # and the stamped letter or letters. From information you give I think its a SMDTA. Compare from actual tractor serial # 67223, engine serial # 8687 and block date code 2-25-Z. Think the first SMTA built was 60004 and used engine serial # 7790 with a 7-13-Y date code. If you have one with a engine serial # over 11595 its not a original SMDTA engine. If you want to change the front bolster to look correct and don't care about original date code, one from a 400 or 450 Diesel is the same as SMDTA one and easy to find. Also a SMTA,400 and 450 gas works but hand crank parts in bolster need switched out to diesel hand crank parts if hand crank parts are wanted.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
