Posted by ih560 on August 23, 2008 at 10:46:21 from (204.118.68.33):
In Reply to: Farmall A Hydraulics posted by old A on August 23, 2008 at 04:10:53:
The super A block has provisions for a hydraulic pump where a Farmall A block does not. If you look below the magneto or distributor you will see a place on a Super A block that has a mounting location for the pump that you will not see on an A block.
In other words unless your A has a Newer model engine in it, then you are not going to be able to use the hydraulic pump from a Super A.
And even if your tractor does has the super A equivalent engine, I would doubt that you would have the correct clutch housing to use the rest of the Super A hydraulics, So you would have to make your own reservoir and control system, which isn't all that much trouble but you are in for a lot of work and money buying valves and cylinders.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
