I'll add to the discussion that if the charging voltage listed in the other posts is not happening (Below 7v) at half throttle or better, try this test: With all things connected, battery charged over night, and tractor running, use an alligator equipped jumper wire (12 gauge is OK) to ground the F terminal of the generator. (it will not hurt anything, it causes the gen to put out max) if the voltage (and charge on the amp gauge now are in the range, the regulator is not set high enough. Adjusting them requires some substantial understanding of the parts inside, New works. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
