Hi Michael, I saved several of Bernard le Mwchano's solutions for these tractors as my brother has four of them. Below is his reply for 3pt hitch problems:
3 pt will not go down:
Hi Butch, there is a cover on the right side,in front of the rock-shaft. Remove and check if the spool valve moves with the position lever. Make sure the draft lever is down. It has a long spring, with a rod, may be the spring is unhook.
Hi, may be the unload valve is stuck. Check with engine running, raise the hitch and pull at same time the remote lever. If the 3pt hitch lifts, you have dirt in the unload valve. This valve is under the seat. Remove the large plug to access this valve. One trick, loosen the large plug for the unload valve 2 turns and start the engine, the hitch should lift if the valve is stuck. It has a small hole in the valve and just blow the dirt with air, replace with new O rings. Bernard le mécano Québec Canada
Micheal, I have the I&T shop service manual for 684, I could scan pages for hydraulics as 484 is the same. Send ne an email. I believe you have my email address.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
