They (on a good day) put out 750 to 800psi. If you put a gauge on it and it is much less, I would say checking the relief valve might be in order. Or a rebuild might be needed. If the gears and case are worn, they are not able to be repaired. If you are using Hytran or = fluid, I would use thicker viscosity oil (30 wt non detergent will be good) If the pressure is up there, a bigger diameter cylinder will work. adding 20% to the diameter will do it. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
