Re: Md Engine Sleeve And Piston Removal
Posted by El Toro on August 25, 2008 at 11:39:46 from (205.188.116.73):
In Reply to: Md Engine Sleeve And Piston Removal posted by EricMd1951 on August 25, 2008 at 10:20:45:
You will need to pull the head too. You will need a sleeve puller to pull the sleeves. You probably will need a ridge reamer so the rings will clear the top of the sleeves. You probably need to check that block bore on the sleeve that broke. Probably wasn't tight enough in the block.
Just remove the rod nuts and cap and you should be able to drive out the rod and piston. Use a piece of 2X2 oak and a big hammer. Hal
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
