Just had that problem on a tractor Sunday. You most likely have a fuel flow problem or a clogged carb. I would start by pulling the carb drain plug and make sure you have a good steady flow of gas from it. If you don't then work back to the tank to find where it stops. If you have a good flow then pull the main jet plug and spray carb cleaner into it with the drain plug out. Then put the plug back in ans spray it some more. Then drain the carb out and put the drain back in and give it a try. If it runs well then you probably have it licked if not you will probably need to rebuild the carb
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
