There should only be one fuse holder. Is that what's missing, or just the fuse in it? If the switch is rectangular, indicating original, like those in the diagrams, it would be pretty hard to remove the fuse holder, as it was just two clamp ends made to hold the ends of a glass cartridge fuse. Or is it the clamp ends are what you are calling fuse holders and you're saying that only one end is there????
And it's entirely possible that there might be a screw with no wire on it, as in the terminal that taps off for the rear light. If you don't he a rear light, there will be a terminal screw with nothing under it.
And if, as you say, you know it to have been jury-rigged in the past, I'd urge three things. 1) Take a breath. 2) Check out the diagrams. 3) Trace the wires that ARE attached to the switch, tell us where they're connected and where they're attached on the other end. We can help you, and you can help yourself, but we're not going to get anywhere without knowing what your current (no pun intended) situation is.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
