The magic smoke is hard to put back in those, so it's probably done for.
I'd suggest starting over with another alternator since you can get a used one cheaper than you can rebuild the burnt one. Be sure that connections are right and polarity is correct before intalling the replacement alternator.
To make the setup negative ground, you literally hook the negative battery terminal to the frame/engine/transmission of the tractor. You would leave the negative terminal bare until you've checked everything else a couple of times. Then connect the positive terminal to the solenoid and, finally, the negative terminal to the ground.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
