If the engine will crank by shorting across the solenoid, you're not getting battery voltage to the solenoid when depressing the starter button. Your solenoid is probably feeding battery voltage to your key ignition switch should be 12 volts. When you press the starter button that should feed battery voltage to the S terminal on your solenoid and the engine should crank. You can use your volt meter to check for voltage on the S terminal when someone else pushes the starter button. Be careful when doing this. Have the brakes set and out of gear. Your are not getting battery voltage to your coil if the engine doesn't start when jumping across the solenoid. Check for battery voltage at the coil with your volt meter with the ignition switch in the on position. You may have a broken wire or not making good contact either from the key switch to the starter button or from the starter button to the S terminal on your solenoid. Hal
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
