Re: International 300 - Info and Value
Posted by Steven f/AZ on September 06, 2008 at 13:25:32 from (24.121.250.95):
In Reply to: International 300 - Info and Value posted by Clarkbug on September 05, 2008 at 18:13:50:
Check the steering very carefully - the utility has a unique steering arrangement and gearbox. I would say parts are not available for the gearbox from anywhere but a machine shop (big $$$).
If it has been used with a loader on it, the steering will be worn from the additional stress...
I have seen some converted to full hydraulic steering with a rotary valve and two rams, but again it would be big $$$.
Also, check the TA - more big $$ if it's bad. To check it, get up to road gear and pull the lever. Let the tractor slow down, then open the throttle. If the engine revs without increasing your forward speed the TA is slipping. Also run it in 3rd or 4th gear with the TA ahead and ride the brakes a bit to test if the TA clutch slips (the engine should pull down on this test).
Engine spec for oil pressure is 75 psi, but anything 30 and up is good.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
