Posted by the tractor vet on September 06, 2008 at 19:29:23 from (76.212.236.90):
In Reply to: 706 overhaul posted by Rich Griffin on September 06, 2008 at 18:41:02:
When ya DECK the block ya only take off what ya need to get it strightened out and then ya have to RECUT the counter bores to get the sleeves to set where they belong . And no you do not cut the pistons down or use a thicker head gskt. Normaly your only talken here .008-maybe on a real bad one .012 off the block and about the same off the head. , but here the kicker ya don't know for sure how many times the head has been done . SOOOOOoooo don't worry about it and put it together the best ya can . Set everything up as the book calls for fit each piston to the bore that it is going inot and give .004 skirt to wall clearance don't plow with it grind feed chop silage or corn with it don't disc with it till ya have over aleast 30 plus hours of break in time change oil after the first ten hours then again at twenty hours then at fifty hours use only a low ash 30 weight and run the 93 octane gas in her and she will be fine.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
