Posted by Hugh MacKay on September 09, 2008 at 02:08:21 from (216.208.58.110):
In Reply to: Re: Leaking 140...??? posted by KRS_MED on September 08, 2008 at 18:30:23:
Keith: Check the hydraulic fluid level with both levers and front rockshafts in the rear position, (down if you prefer to call it that) and tractor not running. Fill to bottom of the filler plug. Before you put the plug back, start the tractor, and at low idle, operate the hydraulics through the full range several times. This will remove any air in the system, plus your certain it's not over full. If much air comes out during that you should shut tractor down and recheck fluid level.
The very best manual for you is the original IH operator's or owner's manual. Depending on tractor and year, it might be called either. Binder Books have the rights from CaseIH to reprint all these old manuals, and do a very good job of it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
