Posted by john *.?-!.* cub owner on September 11, 2008 at 20:29:34 from (75.121.4.129):
In Reply to: 1948 farmall Cub posted by Dale m. on September 11, 2008 at 18:33:12:
Do you hear the magneto snap twice for every round you crank the engine with the hand crank? If not there is an internal problem in the magneto.
Can you adjust the mag so it snaps when the notch on the crankshaft pulley passes the pointer on front of engine? If not the gears on front of engine are out of time. You can cheat it a tooth at a time by removing the governor and reinstalling it on another tooth to adjust if that is the problem. To properly time those gears, you must remove the front bolster, crankshaft pulley (easy to break), and the front cover.
Is the spark at the plug blue and at able to jump at least 3/8 inch? if not, spark is weak. can come from bad wires, cap, or coil getting weak.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
