Posted by JimB2 on September 14, 2008 at 17:52:08 from (99.241.179.24):
In Reply to: 574 Questions posted by Drtravis on September 11, 2008 at 15:06:50:
Hi Travis, never worked on a 574 gas only Diesel models. Re parking brake, check for broken cable, usually breaks at stud at side of transmission case, properly adjusted parking brake and lastly if all the above doesn't fix it then probably someone has driven tractor with parking brake engaged and chewed up the parking brake band in the range transmission under the seat. My brother's IH mechanic says usually to do a proper job the brake drum and band both have to be replaced. This is many $$ in labour as fenders, fuel tank, 3pt housing have to be removed. Some mechanics do a cheaper job of replacing band only in thru the inspection plate under right foot rest.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
