Tighten both screws all the way in, the back the idle out 1 1/2 turns and the main (bottom screw) 3 turns.
There are a pair of timing marks on the fan belt pulley and a pointer on the right side, just in front of the governor. To get in the ballpark on timing, make sure #1 cylinder is on the compression stroke, then turn the engine slowly until the points just open (the rotor should be pointing to the #1 wire). The timing pointer should be close to the first mark as it's coming over the top of the pulley; adjust the distributor as needed to have it break when the mark is close to the pointer.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
