Posted by Janicholson on September 16, 2008 at 10:51:03 from (199.17.6.128):
In Reply to: Farmall A Getting Hot posted by astimpson1 on September 16, 2008 at 09:30:53:
If the radiator core tubes are scaled up with deposits, it will act like that. Look in the radiator (with enough coolant out that you can see the tops of the cores. If they look a bit plugged, it is time to test it for flow. Take out all coolant. Remove the bottom hose at radiator. Get a five gallon clean bucket filled with water. Begin pouring in water into the cap opening about as fast as you can pour it without spilling a bunch. If it backs up and takes it slowly and does not run out the bottom freely. it is plugged. 2 or three gallons a minute is minimumish. If plugged, try a real rad flush product to see if it helps (follow all directions to a T. If still no help, it needs to be cleaned by a Rad shop. JimN
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
