Posted by Clarkbug on September 16, 2008 at 19:22:25 from (72.66.50.236):
In Reply to: 6-volt posted by tbinny on September 16, 2008 at 16:32:21:
I ran into a similar problem on my H recently.
Does the Ammeter deflect to the negative side while running by chance? (I honestly dont know if the 300u has one, but I figured its a safe bet)
Apparently the starter doesnt care about the grounding, and as long as the generator has been repolarized to the correct ground, it will work and charge things just fine as well. Also, your ignition coil should have the wires switched if you intend to run with the negative vs. positive ground.
I switched mine back to positive ground after repolarizing the generator and it is running well.
If you do a search on the positive vs. negative ground, you should find that post thats about three weeks old.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
