Posted by John T on September 16, 2008 at 19:37:52 from (66.244.97.31):
In Reply to: 6-volt posted by tbinny on September 16, 2008 at 16:32:21:
Questions are, is this ok to run to run like this, if not what kind of damage has been done? Would I cause any damage if I were to swap these wires back around? Does it affect how it runs? Any info? thanks, TB in NY.
1) As long as its working and charging its okay to run that way
2) If polarity is reversed and a gennys isnt Polarized before start up, the VR can be damaged buttttttt Im unsure it was ever reversed in the first place (or if so maybe it was corretly re polarized) and if its been working n charging okay then the VR must be okay NO HARM NO FOUL
3) If you swap you need to Polarize the genny before start up cuz otherwise it may damage the VR (if it aint broke dont fix it lol) ALSO if you swap polarity and it has an ammeter the leads needs swapped or it will read bass ackwards
4) If its a coil ignition the coil polarity needs to match the battery for best operation i.e. a polarity swap needs the coil leads swapped also. It will still run at the incorrect coil polarity but theres less spark energy. For Neg ground the coil + gets ignition switch switched voltage while - goes to distributor. For Pos ground the - is wired to ignition switch and + to coil
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
