Posted by mkirsch on September 20, 2008 at 15:53:13 from (67.240.251.254):
In Reply to: SM w/loaded tires posted by kopeck on September 20, 2008 at 14:32:48:
If you've only got 5 lug nuts per tire, that trailer won't have any tires left by the time you get it home, if you get it home.
Minimum I'd haul it with is a trailer that had 6 lug nuts per tire. That's a 10,000lb rated trailer, which will weigh approximately 3000lbs by itself. The M will weigh 6500 with tires loaded, so the trailer will be maxxed out, but it will haul it.
Is that 80" between the fenders? That is the important dimension here, BETWEEN the fenders. The tractor has to squeeze through.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
