Generally, the part of the TA that most often fails is the lock-up sprague clutch that only functions when the TA is in low range. It needs to lock up so the power will be transferred through the planetary reduction gear set when the TA disk clutch is disengaged when you pull the lever back. If you hear a major whirring sound when you pull the TA lever back, the sprague clutch has failed. You still can use the tractor in high range indefinitely without damaging anything further. If the TA works in both ranges, that is no guarantee that the sprague clutch will stay locked up under load. When TA"s start to fail, there is usually a period of time where the low range will work part of the time, and not work the rest of the time, before you lose low altogether. Even if it does work, I would avoid using low when going up hill, because the sprague could release part way up and the tractor would be free wheeling at that point. Also, by design, there is no engine braking when going down hill in low range, so always keep it in high on any hills. I have re-built a few of these over the years, but not in a while. I think you could expect to pay between $750 and $1000 for a re-built unit on an exchange basis.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
