Posted by mhmalcolm on September 22, 2008 at 12:54:48 from (66.66.107.166):
In Reply to: Sticky Second Gear posted by Fighter pilot on September 22, 2008 at 10:33:28:
I suspect your problem has something to do with the detent on the 2nd and 3rd shift rail detent., but you are going to have to pull the top cover off to see and fix whatever is wrong. The hardest part of getting the cover off is getting the bolts out that are usually rusted into the cover or have heads that are too deteriorated for a socket to work. Cutting the heads off with a torch and heating the cover at the bolt holes, especially the ones on the rear, while driving a putty knife into the gasket joint is about the only way to loosen it up. I've had to do that on two different tractors. If they all just unscrew out normally,
you've got it made. You will need some kind of lift, hoist, or a tractor with a loader to raise the cover because it is extremely heavy. The rails are attached to the underside of the cover. Good Luck!
This post was edited by mhmalcolm at 12:55:42 09/22/08.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
