Posted by the Unforgiven on September 23, 2008 at 14:19:29 from (66.146.251.208):
In Reply to: Farmall rims 15.5 x 38 posted by bruce omn on September 23, 2008 at 12:27:21:
If there are any junkers around you can cut a section out of another ruined rim, don't worry about the hole. Cut the rotten area out and weld in the new patch. Then go to any solid area in the rim where the hole will be, get a spot about the size of a golf ball red hot and flatten the corner out, I use a 2X2 square bar for a backer. I am assuming your valve stem is coming off an edge, not a flat area, and you want it to look original. Then drill the hole.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
