Posted by spiffy1 on September 24, 2008 at 21:45:02 from (70.41.136.71):
In Reply to: Stuck 22-36 posted by Clarkbug on September 21, 2008 at 18:46:52:
gregk said: (quoted from post at 21:10:52 09/22/08) If it is like a 10-20 and you can remove the flywheel cover to gently get a pry-bar on the flywheel teeth it will give you more leverage than the hand crank. Gently is the key word as you can break off flywheel teeth if you are too rough
I think that is possible, but afraid gentle isn't often my strong suit with a prybar in hand! :oops:
Haven't worked with it much more, but did check the pan plug - a pint of water! So maybe the governor housing was tore apart before it was shedded, condensation was nastier than I suspected, or mouse urine - not sure if the latter is probable, but there was a nest in the manifold. Also noticed the upper exhaust divertor wasn't seated on one side - maybe 3/8" !
I'm afraid this thing may be planning to put a up a bit of a fight. Next step probably pull the valve cover, and see if I can bring up the open valves. Then at least I can put some air pressure to those two also.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
