Wire her up,,,,,,Connect Battery at Neg ground,,,,,,,,,,POLARIZE the Genny BEFORE you start it,,,,,,,,,,Coil is polarity sensitive i.e. at Neg round its lil + receives ignition switched voltage while its lil - wires to distributor,,,,,,,,,In the even the ammeter isnt wired correct, simply swap its leads i.e. wire it so with tractor off if you turn on lights or ignition it swings over to - discharge then swings to + charge when running at RPM.......
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
