TC - If your M has a live pump the most probable cause is a failing camshaft drive gear. Typically the web between the gear teeth and hub fractures, or the cam gear retaining nut loosens/falls off.
The gear will still drive the cam more or less in time - so the engine will still run. But you'll hear a slap or clunk twice every crank revolution as the gear "flops" fore and aft inside the timing cover.
Repair is straightforward - I've replaced several Super M/400 cam gears. However there's some heavy parts must be removed (entire front end/bolster assembly) to get at the timing cover. Also the nut on the the front of the crankshaft must be removed. The nut is BIG and located in a recess. It requires a 2-1/2" socket - a size not usually in the average M owners toolbox!
However before you tear the tractor apart carefully check also the fan blade/water pump assembly. A loose fan blade or failing water pump bearing can cause ominous sounds at the front of the engine too.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
