I have an IH parts manual for this tractor and it seems the flow diverter is the same for all hydraulic pumps (up to 17 GPM). I agree the 90 degree boss fitting is an abrupt change in direction and I plan to change it to a sweeping 90. As for heat, I have not noticed any significant change in oil temp.
I think first I will change the fitting. Second, get the high flow filter. Third, if required use the .024" gasket to give the gears an extra .005"
As I think about it, I used two gallons of Lucas Hydraulic Booster added to the hydraulic oil after I change the pump to increase oil performance and to control minor leaks. My oil leak is virtually gone at the quadrant.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
