Posted by the tractor vet on October 01, 2008 at 14:07:53 from (99.167.208.219):
In Reply to: hard starting IH 560 posted by Russ Goebel on October 01, 2008 at 12:47:56:
Well One thing to check here is the manifold bolts and make sure they are tight or remove the intake and exhaust and replace the gskt along with having the manifold milled so it is nice and flat to make sure the gskt. seal well . Then keep a check on the bolts as they will loosen up from time to time . Next do a good tune up on her along with a valve adjustment BY THE BOOK.Then put a timing lite on it and set the timing and that sets at rated PTO speed . as for gas dripping out of the carb one has to keep in mind that this is and UP DRAFT carb. and what goes up must come down . Now not saying that ya don't have a needle and seat problem but if it is only a few drops and not a steady run then this is normal on any updraft.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
