That's the problem with trying to keep up with too many threads at once.
Of course, you're 12v.
What you'll have to do depends on what was done in converting your tractor to 12volt, i.e., whether they used the old generator harness or stripped it away. Originally, there was one harness carrying the wires up to your generator and relay/regulator that also carried two wires forward for the headlights.
What do you have for a switch on your panel box? It should be the round knob just below your ammeter. It will have three or four positions to it. The three-position controlled only lights. The four position controlled lights and the charge rate from the generator to the battery.
You will need two wires to run from the back of that switch up to your headlights. (If the harness is still in place and it ever did have lights, you might be able to use the ones that are already there. Otherwise, you'll need to buy some wire. The lights were mounted on short posts with the ends flattened. The round end of the posts fit into the front casting, coming out horizontally, and were locked in with square head set screws. The post on the right is shorter on the A, to allow for the bulge in the casting for the steering gear. The lights mount to the posts on threaded studs through holes in the flattened ends of the two posts.
All the hardware can be found as salvage if you go hunting. OEM has the lights and hardware, as well. They're pricy, but a good set of used lights ain't gonna be cheap, either.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
