The only part that is now longer turning when in 5th as compared to the other gears is the front mainshaft bearing. There is also no load on the countershaft in 5th as there is when in the other gears. Do you hear the noise when idling in neutral with the clutch out?
The front mainshaft bearing can be replaced after removing the Lift-All pump, driveshaft coupler, front input shaft yoke, and the input shaft assembly.
The front mainshaft bearing is often referred to as the transmission pilot bearing. Look back through some of the older threads and you will see a lot of discussion about it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
