Posted by Bucky on October 10, 2008 at 21:38:06 from (208.74.247.253):
My Farmall Super M does not have a dipstick for the hydraulic fluid. I was told they are no longer available, and would probably cost a fortune anyhow. All I really need is to know what the height should be (or should I say depth), from the top of the fill pipe. If you have a Super M with a belly pump, could you please measure your dipstick and tell me the number of inches (or fraction of) from the top of the fill pipe to the proper fluid level. I can easily take a wooden dowel and make my own measuring tool.
One other thing. Where the control shaft lever enters the side of the pump, I noticed it"s very sloppy. I took out the bolt and found there are four notches that need to line up. These are ok. It seems the inner part going into the pump is what is loose, and when I lower the control shaft there is a spot where it gets tight and makes a clunk sound. How do I fix this? Will adding a bushing where the control shaft exits the clutch housing align the inner parts on the pump, or do I need to repair the pump itself?
The pump works fine, my loader goes up and down, but that shaft is awfully sloppy, and sometimes I have to push the shaft all the way where it"s handle contacts the upper bracket that holds this shaft, (from the steering column bracket), before my loader will drop.
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
