Posted by Pete in Holland, MI on October 12, 2008 at 14:08:41 from (24.247.182.9):
Hey guys -
Knew this before my new F-20 followed me home, but there is a crack on the block on the carb side, which is the side I've seen most of them cracked on. It starts from the top and is about 3-4" long. I assume this was from a coolant freeze up at one point. It has some form of sealant on it for now and weeps some. Couple questions:
1) Does a crack in the block in this area have any affects on the life of the engine, other than a puddle on the floor?
2) If it were to be arc welded (I know it would have to be cleaned, end of the crack drilled, keep the heat in control and peen the weld as I go), other than regular old ni-cast rod, what rods have you used with better results. Can it be welded in the tractor (vertical welding) ?
3) The thought I am having is to clean up the area and bolt on a steel plate with a generous amount of silicone sealer under it. Although not authentic, I feel it would stop the leaks. Anybody ever do this?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
