If its now 12 volts (and especially if it has a 6 volt coil) I agree with Old, its likely an ignition ballast resistor that reduces the 12 volts coming down from the ignition switch down to 6 volts for the 6 volt coil. I call them the "bathtub" type they are white/cream porcelain/ceraimic units with a wirewound power resistor inside and are around 1/2 x 1/2 x 2.5 inches or so and would measure around 1.25 to 1.85 ohms or so between the terminals. They wire in series after the ignition switch but before the coil, piece of cake......
Can you tell if its a 6 or 12 volt coil and a 6 or 12 volt genny etc??
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
