c-man's sounds like a new rebuild on the motor so I think it's safe to eliminate hot chunks of carbon or the burrs at the top of the cylinders being hot enough to make his engine diesel.
Cam timing can be off. Though it's still out there as a possible cause, I'll assume for now he got that right or never monkeyed with it at all.
Running an engine with the ignition timing retarded can easily cause it to run sufficiently hot to diesel at shutdown, especially if it has been run up to speed. In my exerience with older, timing is the notthe only, but the most common cause of his problem, and is only more common with the lower octane fuels we have these days as compared to what was available in the fifties.
That is not to discount your advice about his idle speed. If his valves are at all leaky, the angular momentum left in the motor could cause it to turn far enough after shutting down the igintion to draw in more fuel that would ignite. But I tend to doubt that a new rebuild with good compression and tight valves in proper time would run on that far.
My exception was not to your advice about the idle speed. It was only to the statement that timing might have nothing to do with it.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
