Posted by Guyzoo on October 13, 2008 at 18:34:10 from (198.164.97.38):
Hi, since i have my H it always runs rich at idle. I tried advancing, retarding the timing with little or no effects. I adjusted the carb like it is supposed to: main needle two to three turns out and the mixture idle untill it runs smooth on idle. so I am suspecting the governor adjustment Now, I noticed that even if I unscrew the idle adjusting speed screw all the way out the engine still runs at about 500 to 600 rpm. I removed the cover in front of the governor and found two adjusting screws that looks like the ''stops'' for the low and high speeds of the engine. If I unscrew the upper screw in the gov. ( the one that stops the shaft from turning when the throttle is at idling position) the engine still runs at 500-600 rpm with the idling adj on the carb fully out. I noticed an adjustment on top of the governor under the little cover with the steel pipe attached to. Could this be the trouble? I guess a carb and a tune-up kit would help too
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
