Posted by spiffy1 on October 14, 2008 at 11:00:32 from (70.41.136.71):
In Reply to: Is it safe? posted by old on October 14, 2008 at 08:20:02:
I'd say rustred has a much safer plan there, but I have done what you're talking about [have done, not necessarily recommending! :oops: ] - actually a bit crazier yet:
left the spark plugs out and drug it 100ft accross the yard really slow while in high gear to get just enough RPM for to circulate the mixture (some ratio of diesel and oil). It didn't blow up, but maybe I got lucky! After that, you definitely want to do the same with some cheap oil and drain that right away too so you don't leave the bearings dry. That was one I'd broke loose after soaking in diesel and still had diesel all the way through the manifold and cylinders too.
What is yet un-noted though - did this have non-detergent? I've always been of the opinion [though no proof] that if you haven't run detergent oil before - then clean it up or switch to detergent - things can get loose and/or leaky.
Never tried it, but [after seeing a bunch of ATF uses around here] I have to wonder if you're going modern oil to modern oil, if ATF wouldn't be a good rinse? If so, I'd still flush that with some cheap motor oil too though, before putting in good stuff changing the filter and starting the tractor.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
