Posted by adam59 on October 14, 2008 at 14:33:45 from (71.8.60.185):
I have a 674 International that has a hydraulic problem. It has set up for a few years and the 3 pt hitch would not raise. I started by changed fluid and filter. I took mcv off and cleaned it good, took unloading valve off and cleaned it real good. Both of these looked fine. One O ring was bad in the MCV, I replaced it. The 3 pt hitch will raise now. I have lost my brakes though. I guess I need to bleed them off. Not sure of where to do that though. When you raise the 3 pt hitch, it will come up fine, then start slowly leaking down, then you can pull the remote lever up and it will hold fine. Does this mean that I need to take the remote valve apart and clean it? I am not sure what the remote lever positions are? (up is engage?, etc...). I also have fluid coming out around the steering wheel, I'm thinking this is just a bad seal on the pump. I need all the help I can get, thanks in advance.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
