shadetree mechanic said: (quoted from post at 10:21:37 10/06/08) I haven't done this in awhile, so I'm trying to remember the specifics. You'll have to remove the plug under the filter on the bottom of the MCV body. I think it takes a 1 1/4" wrench. Remove the plug, then let the spring fall out. There may even be a valve along with the spring. Put the bucket under the hole and start the tractor. After a few seconds, oil will come flowing out. Shut off the engine and put the parts back in the MCV body. When you start the tractor the next time, you should have hyd. pressure. I have to do this every time I change the filter. They say its because the pump is worn and can't prime itself. Hope this helps!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
