You shouldn't have to remove the radiator. The shroud is in the way, but the job will go a whole lot easier if you remove the fan and the belts (including the generator belt).
And that will be the key to your belt tension adjustment. Your water pump belt runs off the crank pulley and also drives your fan, and the adjustment for the whole belt is at the fan.
The fan is mounted to a slot on the casting that holds your upper radiator hose. The slot SHOULD hold the nut on the back in place while you loosen the fan up. That is done by turning what looks like a nut (but is actually a part of the fan shaft that is machined into a hex) on the front of the slot. In other words, the shaft threads into the nut on the back of the slot in the bracket. You may have to fiddle and try to get a wrench on that back nut if it turns. If so, just hold the nut on the back side -- but do your turning on the shaft.
With the fan and belts out of the way, it's still close quarters, but you'll be able to go over the governor from the right side to get to the other bolts on the water pump and have room enough to wiggle the pump off the hose. Couldn't hurt to put a piece of corrugated cardboard on the back side of the radiator while you do this so you don't ding up your fins. It might also be helpful getting the pumps off and on to loosen the clamps on both ends of the lower hose to give youurself some added twist the geometry of finaglin' it off.
Getting your belt tension back is a matter of starting the fan shaft back onto the nut when you're done. Tighten it just enough for it to hold, then use whatever in the toolbox works to pry it up enough to get the belt tension right, and hold it there while you finish tightening the shaft onto the nut.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
