Posted by Floridaboy on October 21, 2008 at 04:26:50 from (209.149.201.5):
Just wanted to give another update for those that helped. My 674 quit on my while discing. Changed fuel filters, got running, quit on me again. This weekend I took the supply line off above the filters and opened the valve under the tank and had really good flow, so I decided to remove the filters. After removing the filters and line to injector pump I blew air through the bleed hole while blocking the other passages (as best as I could). I got a bunch of black slimy stuff out of the top of the primary side (it hung down like black slime). I removed the assembly, washed in gas and blew out with blow off tool. Put her all back together and less than a minute from turning on the fuel I had a 4-inch stream shooting up out of the bleeder hole. After much cranking, cracking lines to let air out and pressuring tank I got her going. Used her for about an hour and a half with no more problems. I guess when I let the fuel get really low while working it sloshed that black stuff out of the tank and into the filter assembly. Thanks to all that helped with advice.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
