Re: Condensation In Farmall M Rear End
Posted by ScottyHOMEy on October 24, 2008 at 13:30:39 from (70.105.231.41):
In Reply to: Condensation In Farmall M Rear End posted by Bob F on October 24, 2008 at 07:55:13:
Was it just a drain and fill last summer? That as opposed to an open up and scrub her out? If so, I'd just say that you've got old sludge mixing in with your new oil. A few months with clean oil in a clean tranny case, in the absence of extreme heating and cooling in high humidity, would be a very short time to get enough condensation to notice.
Then there's the possibility, if it's left outdoors, of water splashing under or running down the shifter, in which case a pail over the shifter when it's left outdoors would help a lot.
If it's bad enough that you think you want to drain and refill once more, and if it were mine, I'd drain about half or two-thirds out of it and refill to full with kerosene or diesel and give her a good warm run to loosen up and float as much soft sludge as could, drain that while still warm and then refill.
The guy at the local garage with the waste oil heater will love you.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
