If you're talking about a tractor diesel injector pump its not hard. Look at the end of the shaft that drives the pump, you will see a dot near one end of the flat surface, there will be a matching dot inside the pump hole, turn the pump untill the dots will match as you slide the pump onto the shaft. Remove the two screws and the plate on the side of the pump, then slowly turn the engine in the correct rotation. If you have a pump with a stationary mark turn the engine untill the mark on the rotor lines up with it, then tighten the pump bolts. Depending on which tractor and pump you have timing marks will differ.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
