Dr. Bert - A quick way to determine which generator terminal is which is to use an ohmmeter - either a VOM or DMM:
First disconnect the wiring from both generator terminals. Set the meter to the lowest resistance range, ground/hold one ohmmeter probe to the generator frame then touch the other probe each generator terminal in turn. The terminal reading almost zero resistance (usually 0.1 ohm or less) will be the A (armature). The other terminal will measure between about 1.5 and 4 ohms - it will be the F (field).
Presuming the C has its original 3 brush generator, maximum current output can be changed by adjusting the 3rd (movable) brush position. The closer the 3rd brush is to the nearest fixed brush the more amps the generator will produce.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
