Re: Loosener Preference
Posted by Tom Fleming on October 31, 2008 at 18:37:41 from (209.195.155.84):
In Reply to: Loosener Preference posted by Wayta on October 31, 2008 at 14:06:41:
I mostly use PB blaster. I also use Kroil. both produce good results, but my ability to get Kroil isn't nearly as easy as blaster.
Once again, when talking about penetrants, there are a couple of good ones, and then snake oil rears its ugly head.....
If you really want to break badly rusted bolts/nuts loose, heat them first, then treat with your product of choice. Just like when soldering, you heat the piece, and "draw" the solder into the joint with the heat. same with penetrants. Heat the bolt or nut then apply the penetrant. no need to go wild with the heat, ie. don't go to "cherry", just heat to the point that the rust turns color. then soak with your favorite product.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
